I have a 1950 JD MT and trying to remove the rock shaft but the 2 rods that come fro the control levers are holding it from
coming off and the other end up front has only a hole to look in and not big enough to get tools in it to unclip it there. Does
and one have an idea if I need to remove the front cover to unhook the rods? what is best way to get rock shaft off to see the
piston and check everything out?..thanks
