4520BW
On my dads 4020 brake valve the cast has broke where the pin for the pedals goes thru. It has be brazed before but this time the piece fell and is lost. What the best route to take, rebuilt valve,used valve and rebuild it or buy the part I need? The part is $800 new from Deere.
I had the same thing happen on my 3010. What I did was find some steel washers and cut them into two. I used 4 washers that were welded together, I then used that for my lost piece, I then nickel welded the made up part to the brake assembly. It has held up for years.It only cost me a few cents for the fix.
Brian
