John Deere "AN" first run
You did OK, Wished the one I resurrected ran that well at 1st start up.
After tweaking on the carb 20 some times, it now runs real well. Nice hitch
too if you have tools to go with it....
(quoted from post at 14:07:57 09/18/18) You did OK, Wished the one I resurrected ran that well at 1st start up.
I got a harrow/cultivator with the tractor.
Your pictures look real familiar. The tractor I just did was a 44 A, the pieces & parts looked as bad as yours, but I had a Donor tractor
that is about as late as your I got many parts from & changed to electric start. And added the square seat box & float rid seat. Why I did
all of this , I don't know, I didn't need the tractor & have 9 other John Deere's I guess it's just a passion to bring one back to life.
BTW I forgot to mention, you can throw that Live Hydraulic pump & hose's in the back of my truck anytime you like!! LOL
(quoted from post at 08:36:08 09/21/18) BTW I forgot to mention, you can throw that Live Hydraulic pump & hose's in the back of my truck anytime you like!! LOL
I need to look into that pump and see if it works. I am wondering why it isn't hooked up. Right now the pressure hose is capped off and hanging by the rear axle/power-trol. I need to get some info for the pump hookup procedure. I have read that Green Magazine has the service bulletin on this conversion.
Fired up the A today and ran it around the farm for a couple of hours. That got it warmed up good so I could tune the carb some. Its running pretty good, but I do see some smoke now and then when I load it a little. I Hooked up the harrow to try out the hitch/lift and scratched up some ground. The lift holds well and handles the harrow easily.
