4020 stroke control valve
td466
I'm replacing the stroke control valve in hyd pump and I can't seem to get it in far enough to get the plug at the bottom back in. What am I missing ?
Pump is still in the tractor
You will need to back the adjusting screw out to relieve the pressure on the spring.., be careful when driving these in, you can damage the seat,,I have a special tool for this and you can use a 1/4" drive socket and extension for a driver,,this will put the impact on the outer rim and not the valve..
