Wildride47
This may be a Pandora’s box question but I will throw it out there. I have a 1988 JD2555 that seems to be running just fine. I shifted into high range and shifted into 2nd gear and the diesel kept right on T it’s normal RPM but the tractor trans never felt like it hooked up. It keeps moving forward but no increase in speed, almost feels like the clutch is slipping. All the other gears in the high range did the same thing. Does this sounds like a clutch issue or is there something in the trans valve that’s acting up. I’ve never had reason to use the high range since I bought the tractor until this weekend. Fluids are good, filters replaced just don’t understand what’s happening. Low range works great.
