Cast iron or cast steel
Are the MTs cast iron or cast steel. I broke a brake lever and wanted to know if it can be welded?
I was trying to work the pivot point loose and it cracked the bracket.
I would say if it broke versus bend it is probably cast, take a grinder to part of it, the spark will tell you for sure.
