John Deere 3130 (2840) battery
Pasha91
Hi guys,
Wondering about specs on Jd3130 or 2840 batteries. Want to pick some aftermarket ones up - only thing is not sure about the specs... Picked up my 3130 @ an auction recently and came w/o batteries.
Thanks
Parts catalog shows standard battery now available for 2840 as a BCI Group 30 battery, 700 CCA.
2840 PC recommends 2 batteries. 2840's I had experience with needed ""3 batteries"" when attempting to start at operating temp.
just put you one of these on it, it will crank it with 2 batteries..right now I'm using one battery, but I bypass pump and it is not a gear reduction, had another Industrial starter and used it..before winter will be getting another gear reduction..
Untitled URL Link
When installing the batteries I would suggest running the ground cables directly to the transmission case not to the
battery box frame as the original.
(quoted from post at 12:24:19 09/15/18) When installing the batteries I would suggest running the ground cables directly to the transmission case not to the
Ditto on relocating battery ground cable connection from rusty battery box to engine block.
