JDTractorNewbie
New User
Hi - have an old JD2010 w. gas engine, that is in remote northern minnesota used for brushing. After not being run for a long time I ended up replacing both gasket/screen to stop leaking from top of sediment bulb that wasn't properly sealing. After that 'success', however, gas started leaking from carb which was brand new!! ...appears to be coming from where choke linkage attached to carb, but as that is right against the engine block I am not certain if that is correct, or it is just flowing in that direction and dripping down from that point.
I have a couple of questions:
1. How difficult is carb removal/what gotchas should I be particularly careful to pay attention to?
2. There is no room to seemingly access where that choke connection fits with the carburetor to disconnect it - suggestions?
My plan would be to remove the carb and bring it about 30 minutes away to a guy who does JD work as I don't have a heavy enough trailer/vehicle to move the tractor.
Grateful for any suggestions or tip - thank you.
