I was mowing with my 4010 tonight. Up front behind the fuel tank I started leaking hydraulic fluid from somewhere up on top right under the hood. Has anyone had this issue. I think I will need to remove the hood to work on it does the hood and front come off as one piece. Any advice or help is appreciated haven't had the tractor long. Thanks in advance for your help
For hood removal in addition to the spring loaded pin that were mentioned that must be turned on each side close to radiator one needs to remove a bolt on each side at rear of hood. Also if tractor has an air pre-cleaner one needs to tap bottom of pre-cleaner bowl up off of pipe also remove rad & fuel caps
Remove cowl at rear of hood.
Using 9/16 wrench remove two bolts under rear of hood.
Remove grilles and turn latches at upper rear of side panels.
Remove fuel and radiator caps and lift off hood.
Leak could be oil cooler hoses or worn line.
