rebuild laeking JD 2040 sterring valve
8850dave
Does anyone out here rebuild these steering valves as this one sprays oil at the operator located in north central Illinois
Normally those type steering valves can be resealed without the aid of any special tools & don't require any hyd valve adjustments as long as steering shaft with valves/shims is left intact IE not disassembled.
The most difficult part of resealing these valves is getting the 6 large o-rings in their correct locations in the steering housing.
