Unknown John Deere model
rckawall
New User
I have a J/D industrial model that is missing the tag below the seat. I need to identify the model if possible to look up manual and parts. This tractor is a 4 cylinder diesel, factory loader, 3 point and has reverser. What other identifiers can I look at to determine the model? I am in need of parts such as the left lift link and this tractor's link has a knuckle at the top. I have not been able to find any pictures of a link like this. Any assistance is greatly appreciated. Thanks, Rick.
(quoted from post at 18:47:01 09/06/18) I have a J/D industrial model that is missing the tag below the seat. I need to identify the model if possible to look up manual and parts. This tractor is a 4 cylinder diesel, factory loader, 3 point and has reverser. What other identifiers can I look at to determine the model? I am in need of parts such as the left lift link and this tractor's link has a knuckle at the top. I have not been able to find any pictures of a link like this. Any assistance is greatly appreciated. Thanks, Rick.
In your first photo it looks like there is a tag on the side of the transmission case a few inches above the right running board. If it is, what does it say?
(quoted from post at 21:29:17 09/06/18) In your first photo it looks like there is a tag on the side of the transmission case a few inches above the right running board. If it is, what does it say?
I just see where there is a screw where I am guessing the tag or plate was.
If it's anything like the ag model that size, there should be numbers stamped into
the side of the front bolster casting, just above the right front wheel.
Ben
I would bet that it is a JD 400 industrial. That would be basically a JD 2020 driveline with a reverser.
I'm gonna agree with JD seller. I have a
400 with a backhoe. The dash, shift lever
locations and reverser location look like
mine. And yes a 400 is an industrial 2020.
I sure like mine. I mostly use it to patch
and add on to field tile.
(quoted from post at 21:54:14 09/06/18) If it's anything like the ag model that size, there should be numbers stamped into
Ben
Ben
JD didn't start putting serial number in RH frame above frt axle until several yrs after OP's tractor in these photo's was built. I agree with others that tractor in photo's resembles a model 400
