Just purchased 37 model D. Noticed a racket in the front that I first thought was a bad fan shaft bearing. Later discovered it was the tappets clacking. I adjusted
them as the repair manual stipulates. "Set left exhaust valve open position so that all tappets will move. Tighten until no motion and then back off 1/2 turn". They
may not be quite as loud but still making noise. Is normal for this particular engine?
