JD 2010 load control pin leaking
I?ve got a 1973 2010 that I can?t seem to get the leak on the
load control pin stopped. I?ve replaced bushings seals o rings
and all and I just will not stop. Any suggestions. Tia
"Any suggestions.
First male corrections (as needed) to the model number and year, so someone can help you.
2010 (Dubuque) doesn't have a "load pin/shaft" beneath the transmission oil level, draft is sensed by the top link mounting mechanism.
Only seal is "Grommet", Key # 10, and "2010" was made 1960-1965.
<img src = "http://jdpc.deere.com/pimages/T988/T9880__________UN01JAN94.gif">
As Bob previously stated a 2010 wasn't built in the 70's but was built in the 60's so without knowing exactly what model is being inquired about it's difficult to give a correct answer. It appears Bob has you covered.
Clean and dry the area real good. Is the leak at the shaft or around the bushing? How is the fit of the bushing in the housing? I have seen a 2030 leak around the outside of bushing due to a crack in the housing.
