Best way to bump compression on a B
I have a early 47 B that I want to bump the compression up. I?m looking at installing .125 over high compression Pistons. Since the head is going to be off should I mill it for more compression? What about milling the Block? I?m going to port match the head.
. LP pistons for a 50 Bolt right in. May as well have the followers tried up and the cam ground to match the compression. Blend the rough edges out of the valve bowls . Have the machine shop perform a multi angle valve job. Withba dry air filter conversion the HP should approach that of a gasoline 520.
I second the Ray Castner at Extreme Tractor Parts as he has been through all this and knows what works and what to not waste your money on.
