John Deere model 60 Clutch driver
Hello , Anyone have any ideas on how to correct the driver gap off the crankshaft on a John Deere model 60 ? Shim kits .Over sized driver ..Weld and grind ? Thank you
(quoted from post at 17:22:20 09/01/18) Hello , Anyone have any ideas on how to correct the driver gap off the crankshaft on a John Deere model 60 ? Shim kits .Over sized driver ..Weld and grind ? Thank you[/
quote]
don't understand what you are doing, if you have had the driver off did you put the loose disc in before you put the driver back on the crank?
Hello Kurt, Yes I put the new clutch disc in before the driver. Thank you for your reply .. I tried to send you a more detailed reply from my phone but I don't know if it went through.
