fan belt 2240
Had to replace the water pump on my 2240 JD so decided to replace the fan belt. But my service manual has not arrived so need assistance in how to replace the fan belt.
Pretty easy if you have the rad off to replace the water pump. Disconnect the pump
drive coupling on the end of the crankshaft, slip the belt on, adjust alternator to
tighten belt. Make sure to clean and properly reconnect pump drive coupling.
Ben
(quoted from post at 14:10:13 08/29/18) Pretty easy if you have the rad off to replace the water pump. Disconnect the pump
Ben
thanks Ben, another question, does the pump drive run under the fuel tank? Is there a secret to re-installing the coupling? thanks again
It should be evident where the coupler goes, under the tank where the pump is
located. No trick to it, just be sure the two pieces that bolt together are re
assembled with the bolts installed in opposite direction and that all contact
surfaces are clean. If like mine, these pieces are aluminum and won't tolerate any
mis alignment.
Ben
(quoted from post at 05:12:32 08/30/18) I would install a new set of the hyd. coupler rubber bushings if I took one apart.
Thanks Mike just ordered the 4 bushing kit. Next question: where can I get a parts list/diagrams.
