JD PTO air pump?
I?ve wondered this for years ?? If anybody would have an idea I?d buy one in a heart beat . Just don?t want to get one and then it don?t have the gumption to blow up a beach 🏖 ball ⚽️
i pumped up a brent 544 wagon tire they use a used truck tire to around 50 psi once took quite a while and it was slapping pretty hard the higher the pressure got, it then broke the casting that goes around the pto shaft sleeve not to many uses later, coincidence? im not sure. i welded it back together and still use it to this day. 30 psi in a auto or implement tire isn't much of a problem. can take a 15" car tire and inflate it to 30 rather quickly. i keep mine in the tool box on my trailer and use it mostly at tractor pulls if i want to adjust my pressures a little and around the farm if its easier than carrying a portable tank to the flat tire
I just used mine on Saturday while baling hay, field had a dogleg to it & seen the rear tire on the wagon load of hay was LOW!.. The guys were using my Old POS
Model A deere to haul with & knew the pump was under he toolbox.. It pumped the tire up to 35 pounds in no time with a load on the wagon.. Worked well enough
to get the wagon back to the barn & unloaded where later I found a roofing nail in the tire??
