1956 420W all green
boler76
According to the JD Parts catalogue this is a Row Crop Utility with the straight square front axle . I need a bushing that is part# M3292T by the diagram
in parts cataloque on section 40-6, Ordered this bushing and it came but is too big. I have owned this tractor for last 50 yrs and it has never been apart
previously, the bushing I need is 1 9/16 OD and 1 3/8 ID, the JD part is 2" OD, has anyone else experience with this problem? Thanks
If you put in the part number at jdparts it will show you the dimensions. That way you'll know if it was a packaging error.
I have checked the dimensions and the part I got is same dimensions as shown in JD parts but they are not the same as used in my tractor, was wondering if out of all the thousands if mine is the only one with smaller than listed dimensions???
The rear bushing (item 46, p/n # M1111T) has an ID of 1.454", OD 1.563", and a length of 1.00". That is close to the dimensions you posted. Wonder if they made a change and put a heavier bushing in front?
Thank you, my question has been answered, I was looking at the diagram bassackwards, I will
blame it on vintage (mine)
We all have those days, sometimes more than we want to admit.
Hopefully the dealer will take the wrong one back when you get the other one. Good luck.
