John Deere 2140 rocker shaft plate
I recently bought a John Deere 2140 1978 I think and noticed the rocker shaft plate was busted. I got all the bolts out and unhooked linkage to it. Just wondering how you raise it off with the linkage still hooked up inside.
Welcome to YT
There's no need to post multiple threads asking the same question. If rocker shaft plate is the rockshaft housing then once all bolts have been removed just raise RS housing straight up & linkage will slide apart. Upon reassembly one needs to be sure cam follower(key 11) shown below is behind roller in control linkage.
