My newly purchased 420, after driving it around my neighborhood (not a work tractor...parades, just to own) started leaking trans and axle fluid
on the right side. Drove it again today and leak is more prominent, splatters on inside wheel rim. Once tractor stops leak persists ffor short
period and then stops. Is this a seal issue or should I try to tighten the 4 bolts at the end of the axle? If a seal what is the repair? I do not have
the proper garage or equipment to tackle this on my own. We have a local JD dealer and I am told shop rate is 75/hr. Other than the leak,
tractor looks and runs very well. Thanks...
