5020 Injector Clamps
I bought a 5020 that came to me in pieces. We replaced the injector pump and I need the spring that goes in the end of the pump and pushes against the gear cover. I also put new injectors in and need some injector clamps to hold them down. Does anyone know where I can get these pieces? It is a 1967 model if that makes a difference. Thanks,,, Mark
Do you also need the pin in end of I.P. pump shaft outside of spring? (R36539) is nla from DEERE, wonder if a Stanadyne service center could come up with one, or you'll have to look for used or NOS. Spring is R36540, still available from DEERE for some $4.00.
As to the pencil injector hold-down clips and bolts, R34760, still available, some $12 through a dealership.
A quick look at Parts Depot shows ONE pin available, they don't sell direct, many DEERE dealers are set up with them, cehck if you need one.
