4010 fuel gauge
Joedirt4160
New User
Hello all! I have a 4010 diesel and the fuel gauge was not working, the gauge was busted and the sending unit was leaking so I replaced it.my question is the gauge....the tractor is 12 volt positive ground, what gauge do it need or what do I need to change to make it work? The old gauge has to terminals and the new one's that I've seen have three. Any help would be wonderful. thank you!
For 12 volt positive ground (the old 24 volt system) use RE54427 gauge and AR26434 sender
for 12 volt negative ground (systems that have been switched to 12 volt negative ground)
use RE53664 gauge and AR26434 sender
