I've been cleaning metal out of the rear of my 1020 that my grandfather got repo probably in the early 70's. I assumed all the fine metal that was in the rear came from spider gear failure about 20 years ago and just not cleaned out properly. I removed both axle housings to clean them out and replace the brake seals and clean them out too. Upon looking closer, I found that brake piston on the right side was updated and the left side was still original style. Looking closer the right side has deep grooves and wear in the rear end housing where the brake disc friction material rides against. Near as I can tell, the rear housing has been chewed out about .250" deep comparing to the other side. If I measure where the groove begins, it measures exactly the same depth as the other side. So I guess this was where the metal came from about 45 years ago and never cleaned out. It isn't any wonder all 3 pumps were trashed. Guess my question is what happened to caused this? I guess since it's been that way this long it shouldn't hurt to put it back together this way. I assume probably the only way to fix it properly would be another rear end housing? Sorry for the long post and thanks for any input. And by the way Merry Christmas!
