I recently installed my brand new WICO C magneto and spark plug wires and got the tractor up and running. I had posted a question on this forum about how to time the magneto and many of you fine folks helped me to do it properly. When this tractor runs, it seems to run great. There are two problems with it however. It is very hard/temperamental to start. It takes a lot of tinkering with choke and throttle and it seems you have to get it just right to fire but not flood. Often times I just take a plug out shoot some starting fluid in the cylinder and it fires right up. This is not the primary issue I am having, just mentioned it in case it is related to the next issue.
Now the other, more annoying issue to me is the plug fouling. The plugs that were in there were an NGK variety. I can run these for about 20-30 minutes until they foul and the tractor shuts down. This is a dull black coating which to me looks like excess fuel/carbon build up, not an oil burn. The tractor does not smoke at all when running, either black or blue. Current idle needle position is ? of a turn out, and load needle position is 1 turn out. Air cleaner stack is removed from front of carb to make sure airflow is okay.
I had read that many folks on this site recommend Autolite 3116 plugs. I bought a pair and brought them back and the tractor simply would not run with those plugs. I have no idea why. Does anyone have any idea what else I can try and do to prevent the fouling?
