So my 51 Deere B was running pretty darn good about 3 weeks. I ordered a carb gasket kit to repair some worn gaskets, and I also ordered a new throttle handle as mine was broken. Took the pedestal off to repair the throttle handle, took the carb off to put the new gasket kit on. I also cleaned up some wiring related to the headlights, someone had wired in a secondary switch that I wanted to get rid of.
Ever since, I can't get the tractor to start. Now I know the carb is clean, I've been through it several times. To confirm that fuel is not the problem, i shot starting fluid into both cylinders then tried to start it and nothing. A small cough at best. Must be electrical?
I checked for spark at the plugs and it looked okay. I took a section of wire and ran it from the mag to a section bare metal. It would jump a good 3/16 to 1/4 inch gap. Seems to me mag is okay. I also tried to pull start it (maybe mag impulse is bad) and got nothing. Plugs and wires are the same from when it ran 3 weeks ago. I took off magneto and retimed it anout 2 months ago, it ran well after. Timing shouldn't have changed? I have tried a new condenser, did not help. I compression tested it and cylinders are good. Took valve cover off and all valves are moving.
What am I missing? I am unbelievably frustrated at this point.
