The tractor is up and running now, but is not running super
smoothly and seems to be running rich. The exhaust contains
puffs of black smoke. I believe this to be a rich condition, it
doesn't appear to be burning oil.
I just rebuilt the cap end of the mag (new cap, rotor, points,
condenser) and timed and installed per the service manual
procedure. From the electrical end timing should be good.
I verified that all the valves are opening and closing, and
adjusted tappet clearance per the manual.
I did take off the carb and clean the best I could. I did not drill
the passages, I don't have the bits. Could a carb contribute to
rich running conditions? I typically think of carb problems
generating no fuel/lean conditions. I have the needles set to
one full turn out. The float level seems okay, if anything a little
bit low. What else can I look for that would be causing a rich
running condition???
