(quoted from post at 13:58:02 01/26/17)
Hay maker2
Do any of your 1010/2010's have diesel engines?
I was employed by a JD dealer from '66-'87 and have plenty of hands on experience with a 1010/2010. Granted the 2010 gasoline engine models weren't too bad once one overlooked their poor brakes,hyd systems & weird pto engagement but the diesel engine models gave a lot of problems. I also remember the pre-combustion chambers that gave problems in the diesel cylinder heads. Most 2010 diesels are difficult to start in cold weather and smoke similar to a old steam locomotive. Then throw in the Prestolite starters with the funky starter switch shown below.
No diesel engines here. I do agree that there were major issues with the diesel's and I would not consider buying one. This post involves a gas engine.
I also replaced my Prestolite starter with a Delco years ago. Then again everyone complains about the Delco starters being junk on a 4020....
I am not disputing the low hydraulic pressures / volumes or the weird PTO engagement. Look at other colors of that generation and the 1010 and 2010 are comparable to them in power and features. Yes there big brothers (3010 / 4010) were introduced with industries changing hydraulics (brakes, steering, rockshafts) and other features too. As time went on the 1020/2020/2510 replaced them and the newer and better options were implemented on these new models. Just like the 4020 was a newer and better model than the 4010 and so on....
I also have a 430 (I own 17 tractors in all). I would much rather work on the 1010 than the 430. There is more space between the radiator and the front of the engine that the 430. Yes there is a steering shaft that runs through the gas tank and I would rather work around that than the 430.
Trying to compare a 1010 or a 2010 to a 3010 or a 4010 is like comparing a Yugo to a Chevy. Its not a fair comparison to either.
