I got a 5020 with a very bad clutch chatter. When I engage the clutch, the tractor makes like a grinding noise, and you can feel the uneveness of engagement
The story:
Got the tractor, was told it had issues, which it sure did. First thing is that it did not want to shift in any gear >
1) I splitted at the clutch, found the cast iron plate between the 2 disks broken. The disks were not looking great so I put 2 used ceramic disks that I had. The pilot bearing was totally gone, I toaught this was the source of the problem. I removed the clutch / PTO shafts and changed the seals, then put it back together. I forgot to order a clutch bearing, so I did not change it.
2) Then I could shift. Found out that there was still an horrible noise on clutch engagement, and that I did not have the high range (3-5-7-8) This time suspected the trans. I splitted at the trans. Found that the input shaft front bearing was loose. I replaced the shaft with a used one, replaced the fork that was pretty bad, pu new bearings on countershaft and input shaft and put it back together and tried.
3) Now it shifts prety well in all gears, but I still have a terrible chatter at clutch engagement. I cannot safely use it...
Have you ever seen that? What components needs to be checked or changed?
The fact that the intermediary plate has been broken is probably the origin or the concequence of the problem. What would be the correct way to check this? I am going to split again, and I do not want to split 3 times.
Also, I did not change the release bearing and it was a mistake, it is running very hot (I replaced the hose, so there is grease for sure...).
The story:
