WildfireFarm
New User
Hello to everyone. New to YT and the forum. Need some advise and direction. This is a bit lengthy but please bear with me. A little history - JD 2940 2-wheel drive, w/Sound Guard Body (SGB). Have had the tractor for about 15 years. Last fall the steering and implement lift started going haywire so I drove the tractor to a repair shop (about 8 miles or so). This particular shop is the only independent shop in the area (he specializes in JD and has been in business for over 30 years). Anyway 3-months and $5000.00 later I have a new front pump, pump coupler, steering cylinder kits, water pump, and a new hydraulic oil line grommet in the trans (had to split the tractor). Back home (drove it) and the rockshaft housing is leaking pretty bad. Drove it back to the shop. 2-weeks and $500.00 later I have a new o-ring ($1.00) in the rockshaft. Seems like R&R of the SGB is a major undertaking. Now to the current problem. When I got the tractor back as I was hooking up the ditch bank cutter to do some bush-hogging I noticed the triangle warning light on the dash. Not seen that before. Checked and that pointed to other warning lights, one of which is the "transmission low pressure" light. Further investigation found that that bulb was missing (so I was not seeing it). I put a bulb in now I see the "Transmission Low Pressure" bulb glow. I realized that the light came on only when the Hi-Lo (Turtle/Rabbit) was in Low. In High the light would go out. I checked with the repair shop and was advised that he would just use in in Hi and not worry about Lo. That part of the trans was to difficult and expensive to get to and he would not advise it. I'm dealing with 16 acres and have used the tractor as he recommended to bush hog ditch banks; pulled a 9-tine chisel plow and 12-foot field cultivator preparing the field for planting beans. I've even used it in Low periodically for end turn arounds and when the chisel plow would load. It seems to work fine in all gears, ranges and conditions. That light really bugs me. Something is not right and I want to fix it if possible or $$ feasible. My reading tells me that the Hi-Lo Clutch Pack operates with Hydraulic pressure in the Hi range and Clutch disc Friction in the Lo range, so why the low pressure light in Lo and not Hi range. Has anyone ever experienced this? Could the mechanic have done something inadvertently and not realized it. Is there a simple pressure test to determine where the problem might lie. As I said, R&R of the SGB is a bear and having to split the tractor again and go into the trans is my last resort. I have done nothing at this point. Any advise is appreciated. (Apologize the lengthy post)
