Sonny in Mn
I've been assembling a 51 B that I bought several years ago with a stuck engine. When I attempted to install the oil filter, it wouldn't tighten, the big nut on the cap bottoms on the filter stud before the cap seats on the gasket. I removed the cap & filter element & looked up inside. The filter outlet plate is missing & the top of the filter body is partially collapsed downward. I believe I have several options & I'm looking for opinions or experiences with similar problems. #1 Remove filter head & attempt to straighten housing. #2 Install a brand new housing. #3 I have a junked 50 with a nice straight housing if I can remove it without damaging it & install that one. Has anyone out there successfully removed a filter housing? I am thinking that a piece of all thread & a couple discs would work to pull the housing, perhaps it would also straighten the one in the tractor. Thanks in advance for any help. Sonny
