As far as a direct HP replacement, I do believe the 4030 was slightly lighter, the 4230 was slightly heavier, the 4040 was pretty much the same, the 4240 was about 20 more hp, and heavier, the 4050 was probably similar to the 4240, with a 4250 being about what the old 4430 was, and a 4050 being close to a 4240 or a 4230. I feel that a direct replacement with sound guard cab would be 4040, pick quad or 8spd pwr shift, way better clutch, better brakes, stronger front end, nicer hydraulics, better load control, WAY better electrical system, and overall a pretty good tractor choice. I am not a huge fan of the 30 series tractors, they had a weird electrical system, proprietary to them, the dealer says they had a sort of weak transmission, down in A range there is a bronze bearing instead of roller bearing, and it will gall in certain circumstances, so heavy work is to be done in B range, The load control had a different sort of stop for the reverse draft, that only lasted in the 30 series and was updated to more modern in the 40 series. Last but not least seems to be the rear end, In my country, A lot of 30 series have been decommissioned due to rear end issues, Never seen much in a 4030 but 4230,4430, and 4630 all had rather light rear ends, and had issues with axles failing or breaking, Seen a bunch do it. Not good baler tractors nor good for heavy draft work with full weights. Probably good planter tractor, fair loader tractor, good blade or bean tractor, good sprayer tractor, good hay rake tractor, good feed mill or tub grinder tractor, good manure spreader tractor, On another note, in my area 30 series are about the lowest priced tractor, about the same as 20 series, less than 40 or 50 series.
