John Deere H family of Implements
primerk5
After seeing the M implement thread I thought I'd ask if there was some sort of list for the H. I had done some googling and only come up with a plow and planter and cultivators. At least from what I could find for pictures.
Is there some sort of list. Be nice to keep an eye out for implements that would fit my H.
I think this has been asked here before, I remember a whole list of things. Maybe do a search? I have an H1 plow, cultivators, and rear mounted two row lister. I know a neighbor has a 1 bottom disc plow for his. Keep an eye out for front wheel weights if you want to plow. They are harder to come by...they make a huge difference.
I'm in Ohio and over the years I've had many H's come and go. Seemed to be a good area for them ? Many were used as cultivating tractors and saw a few with H1 plows on them. I'm sure there were plenty of things made for them but you just did not see them in my area.
JD also made a Bean Puller for a Model H, i have one and also have the sales Brochure and parts catalog. In the Bean Puller Brochure it
states that these Bean pullers were only sold in the State of Michigan.. Another neat H implement is the Rare 2 way mounted plow.
J.R. Hobbs listed the following implements as being matched to the H in his book, The John Deere Styled "Letter" Series.
H-1 Integral plow
H-3 two way plow
No. 51 one bottom plow
No. 52 two bottom (12") plow
Nos. 100-B, 150-B small disk tillers
No. 10 series one or two disk plows
"J" single action disk (8 or 10')
"JB" or "KB" double action disk(5 or 6')
"CC" field cultivator (5 or 6')
H-40 two row bedder-middlebreaker-lister
No. 999 two row corn planter
No. 290 two row corn planter
One or two row potato planters
No. 260 bedder-planter
H-630 integral four row cultivator(beet, bean, vegetable)
H-622 six row beet and bean cultivator
AB-17 integral high blade potato hoe
Tractor grain binder (6,7,or 8')
Level-bed one row potato digger
No. 82 sweep rake
No. 88 cultivator
H-688 integral four row bean harvestor
No. 5 mower
No. 92 two disk plow
H-10 one row middlebreaker
H-20 two row middlebreaker
H-30 two row middlebreaker
H-200 series two row cultivator
No. 241 cotton and corn planter
H-140 one row combination bedder/planter/fertilizer unit
H-240 two row combination bedder/planter/fertilizer unit
Other drawn implements in proportion
Let us know when you get an example of all of these implements collected and restored! ;-)
Lon
I have several photos of a model 101 semi mounted corn picker on an h as well. The 101 manual even shows it on the h. Not sure it ever handled it!
Here is a list of integral equipment you can start looking for to hang on your “H”.
H-1 One-Way Plow (12-,14- or 16 inch bottoms). H-3 Two-Way Plow (12- or 14 inch bottoms). H-4 Two-Way Plow (14- or 16-inch bottoms). H-5 / H-10 Plows in (16 inch Slat or standard bottoms). H-10 Single-Row Middlebreaker, H-30 Series and H-40 Series Two-Row Middlebreaker and Lister. PH-40 Series Two-Row Planting Attachments, Fertilizer attachments for H-40 Middlebreaker-Planter, H-40 Combination Unit, No.241 Two-Row Cotton and corn Planter (Fertilizer and Pea attachment available). No. 260 Two Row cotton and corn Planter (Fertilizer and Pea attachments as well as a variety of sweeps and middlebreaker bottoms available). No. 240 Two Row cotton and corn Planter (Fertilizer and Pea attachments as well as a variety of sweeps and middlebreaker bottoms available).PH-200 Planting attachments (for use with the H-200 Series Cultivators) FH-200 Series Fertilizer Attachments. H-109 Single Row Cultivator, H-200 Series Two-Row Cultivators (several varities), H-622 Multi-Row Vegetable Cultivator. H-630 Multi-Row Vegetable Cultivator. No.88 Multi-Row Beet and Bean Cultivators, Multi-Row tool-bar attachments (for H-200 Series Cultivators), AB-17 High-Blade Potato Hoe, AB-18 Disk-Type Potato Hoe, No. 77 Eight-Row Cotton Duster, No.82 Sweep Rake, H-688 Bean Harvester attachment (for H-200 Series Cultivators), H-8-E Two-Row Peanut Puller, No. 86-E Two Row Peanut-Puller Attachment (for H-200 Series Cultivators).
For the pull-type equipment that would match up with the “H”.
The 8-Foot Model “D” single-action disk harrows, 5-foot “KB” and “DA” double-action disk harrows. John Deere-Van Brunt 8 x 8 Grain Drill, No. 4-A Corn Sheller, No. 450 Four-Row Corn Planter, John Deere Power Mower, John Deere Delivery Rake, 8-Foot John Deere Tractor Binder, 6-1/2 Foot “CC” Field Cultivators, Model “H” Manure Spreader, No. 100-B Disk Tiller. The No. 52 plow with two 12-inch bottoms. And much more !!
Thanks for providing the data on these. Gives me something to keep an eye out for. I doubt i'll have much luck finding anything, that isn't already in the hands of another collector with an H but you never know.
Was there a special bracket to connect to the number 5 mower. I don't think that the H will support the mounting bracket parts for the No 5 mower.
found this
I found a 101 picker but have not tried to put it on the H yet.
Another question, anyone have a duplex valve on your pump? Thats one thing i have yet to find.
Closest I got to a duplex valve was ( IIRC ) the valve with part of it broken likely from water freezing in it.
Mike, what does (IIRC) mean? I figure I should know but I have a mental block LOL. Water freezing and busting those valves was very common. Are you looking for a duplex valve? You can email me.
