Please bear with me as I am posting from my phone. I washed the tractor real good the other day and after it wouldn't start acted like no ground. Figured I knocked off a wire so I started digging into it. I wiggled a few cables at the switch and it started. Yesterday I went out to start the tractor so i could do my fluid change and hydraulic replumb and it's deader than a door nail. I might have left a switch on but the tractor batteries were dead when i got it. . I am charging the batteries but it looks like someone has messed with the starting circuit on this. I found a wiring diagram and my tractor is not wired like it. My tractor is 24v but the negative cable on the left side is going to the back rear of the starter and the positive is going to the top solenoid post, in the diagram it is reversed. In addition the is a set of blue wires and brown wires that are tied together on mine and going to the same top post on the solenoid as my positive, where as the diagram has the 2 blue wires going to the top solenoid post and the two brown wires going to the bottom left. In addition there is an added wire going to the same solenoi post as the yellow wire that goes to the starter button bypassing the clutch safety switch. All other wires match the diagram an dress far as location and continuity. What has the previous owner done here? Should I change it back? Could this current set up be killing the battery? I will follow up with some pictures of diagrams in a minute.
