bernieinva
I recently purchased a new Meyers spreader. Good machine and heavy duty. However, I ran something through the spinners at the rear of the machine and actually broke the shaft on one of the gear boxes that feeds one of the spinners. The machine has a slip clutch at the pto shaft at the front of the machine 15' in length. Power to the spinners and gear boxes at the rear is from a 1 1/2" shaft traversing the length of the spreader. I realize the slip clutch at the front machine primarily protects the drive mechanisms for the augers but seems to me to do little for the spinners at the rear. If it did slip it did not do its job. Am I not correct in thinking that if something jams those spinners, either a slip clutch or shear pin should be right at the gear boxes and not at the front of the machine?
