The ammeter on my John Deere 60 reads about -7 to -9 while the tractor is running. Interestingly, when lights are in use, this number is reduced to -4 to -6 (while running) or +3 while tractor is not running. I looked at how the regulator was wired by previous owners. It is a 4 terminal regulator like the one I just installed on 48' B. The previous owner had both the wire to the ammeter (white) and the wire to the light switch (black) on the L terminal of the regulator. The BAT terminal was left unused. I disconnected the battery, rewired the regulator correctly, reconnected the battery, then polarized the gen to the regulator as a precaution. Unfortunately it is still showing a negative charge while running. Has anyone encountered this problem and what are some possible explanations? Thank you.
Sincerely,
Peter Markel
Sincerely,
Peter Markel
