John Deere B light switch/harness
pmarkel
I have a 1948 John Deere for which I am attempting to restore normal light function. I thought I would modernize the light switch to one with a fuse. The tractor has a 12 volt system with a voltage regulator. Is there a particular light switch I should be looking for or will any universal one do the trick? Thank you for your time.
Sincerely,
Peter Markel
"<font color="#6699ff">[b:654c4848f0][i:654c4848f0]Is there a particular light switch I should be looking for or will any universal one do the trick?[/i:654c4848f0][/b:654c4848f0]</font>"
Take a look at the diagram below.
a198034.jpg" width="650"
Note the [b:654c4848f0][i:654c4848f0]BLACK CONNECT TO REGULATOR TERMINAL "L" & LIGHT SWITCH[/i:654c4848f0][/b:654c4848f0].
Take a look at the photo below.
a198035.jpg" width="650"
You might consider using a "universal" light switch and installing an inline amp fuse on the black connection lead.
Hope this helps.
Thank you that does help. I will study the generator on the tractor tomorrow and compare it to your diagram.
