Is turning this engine over with the flywheel and listening for the mag to snap a good way to check the timing? This is what we did and then when it snaps and we look at the timing marks they are off from tdc. The marks are right cuz I went by the piston coming up on the left side. We were real careful in checking every thing, then went and rotated the mag but we're not able to get it turned far enough to get it timed this way, of turning it over by hand till the mag snaps. Also when the piston is at tdc, I notice the slot that drives the mag is not parallel to the ground, it's leaning ahead. What could have caused this to get off. Or possibly been put together wrong years ago? Also it won't hand start right now,have to use a belt to start it, but runs good then. We're going to put in points and condenser even tho the spark does jump 1/4 inch. Fuel is there and will sometimes get flooded in trying. Haven't tried shutting the peacocks when cranking, but seems to have enough compression when cranking. Just a question on the timing and then we'll work from there. Thanks
