Was looking at buying a 450b with 6way blade. It steers fine in forward both left and right. I reverse however it will steer to the right but when I pull the left lever it shutters, bogs the engine and slowly turns (doesn't bring the left track to a stop like it does in forward). The seller said it was from sitting and may need a little adjustment :roll: but for the life of me researching this I can't come up with a logical reason why it would act this way only in reverse and perfectly fine in forward. The undercarriage was redone to some extent recently. owner said the final drive was redone and I can see the drive chain was redone as the measurement across 4 links is at 100% where the right side is -120%
Another question is with the blade raised up it will fall 3-4" in a couple of minutes with the machine running...is that a sign of any hydraulic issues??
Looking for any ideas as to what the cause might be.
