A week ago, I posted for some information about getting that bolt loose and out on the left side of the tractor. I set a lever jack on the step under a 15/16" wrench and jacked it up tight, left if set over night and was able to give it one more notch in the morning. I gave the cap screw a few whacks with a hammer and let it set until afternoon. Late afternoon I was able to jack the wrench up to where I could get the bolt (screw) out. It didn't help me, though, because I couldn't observe any play in the splines that I was hoping to be able to tighten up, so I just set it back together using thread loc. Support the step from below, if you do this, so you don't bend it down.
Does anybody else know where to look for a solution to tighten up the steering? I can turn the wheel a quarter turn without the arm below even moving a bit.
