super 55
- Location
- Whonnock BC
Hello, I have a backhoe(John Deere 510C) sitting on my property I need to move, but am having some trouble with the starter. It's not my backhoe, just storing it for a neighbor down the road that seems to have forgotten about it. I bought a new solenoid to install, put it on the starter and installed them in the backhoe. I can get the starter to spin when I push in the starter button, but the solenoid isn't kicking in the bendex gear. Is there a way to bench test the solenoid? The way the solenoid wiring was hooked up was (see photo) There was the positive cable from the battery and another smaller wire from the battery hooked up to terminal "B" . Wire "A" goes from the solenoid to a post on the side of the starter body. Terminal "C" has a white wire that comes from the harness, which I would assume would be the starter button. The wiring in the machine is quite a mess of splices and taped off contacts, but the starter was working at one point. Terminal "C" also has a copper strap that goes to the starter field post. Can't seem to get the magnet to kick in. I am not good at electrical problems and would appreciate anyone's help to get this thing working. I want to move it away from my building.
