Late A battery box
donwisc
11-19-2013 13:25:22
I am looking at a late 1952 A that has a larger box similar to an A or 50. Did that come out as a factory install. or would this be a conversion to 12 volt using the larger battery box.
Carlyle Hoffman
11-19-2013 13:55:47
 Re: Late A battery box in reply to donwisc, 11-19-2013 13:25:22
52A,s among others earlier, came FACT large box 2 6 volt battery's making 12 volts. Basically the 50-60- and70gas same as. Where as the early A,s and all late B,s had 1, 6 volt.
rla
11-19-2013 13:52:08
A late A should have a large battery box. Big enough to hold 2 6v group 1 batteries in series.
donwisc
11-19-2013 14:32:56
 Re: Late A battery box in reply to rla, 11-19-2013 13:52:08
Thanks guys for the info, its the first time i seen this setup so it means i havent seen many or any late Bs
Bob Collins
11-19-2013 14:37:32
 Re: Late A battery box in reply to donwisc, 11-19-2013 14:32:56
Your first post said late "A", now you say late "B", I suspect a typo. Late "B' tractors had a small battery box for a 6 volt battery, BUT there was an option for a heavy duty electrical system with a big battery box. I have never seen one and don't know if I have the terms correct.
donwisc
11-19-2013 15:55:55
 Re: Late A battery box in reply to Bob Collins, 11-19-2013 14:37:32
Sorry guys, had a brain freeze. I knew about the A's and I meant to say late B and now it makes sense.
Bob Collins
11-19-2013 16:04:25
 Re: Late A battery box in reply to donwisc, 11-19-2013 15:55:55
And the conversion kit was number AB4293R which was a modified "A" battery box to hold 2 six volt batteries wired in parallel for more cranking power in extremely cold staring conditions.
