JD A and B front wheels/tires
young gun
10-22-2013 13:54:35
I am attempting to get the front end of my 52 A to sit lower than it does for pulling purposes. Right now it has 650/16 tires on it... should I just look to get smaller tires to fit the rims or would the rims (if any smaller in diameter) from a B or other model bolt right up to the hubs on my A? Thanks for any advice
Dane
Carlyle Hoffman
10-23-2013 14:49:37
 Re: JD A and B front wheels/tires in reply to young gun, 10-22-2013 13:54:35
Front rims from a late (H) , will also fit.15" and narrow, with a STRAIGHT PEDESTAL, no roll-matic do the job.
Craazyhoss
10-23-2013 05:38:38
Friend of mine pulls a G he swapped some 5 bolt trailer hubs onto his tractor with 14" rims with 18.4-34 rear tires looks funny but pulls like all get out
young gun
10-22-2013 16:54:06
I guess my next question would be dies anyone have any leads on where I could get ahold of either of these items? Either B rims/tires or the straight pedestal as Mike mentioned. Thanks fellas
Doug Sr.
10-22-2013 16:05:11
A friend of mine has a 50 that he pulls. He cut the centers out of Farmall Cub and welded his centers in them. That dropped the front end down a good bit.
Doug
Bob Harvey
10-22-2013 15:35:44
You might lose some hite using low profile auto tires. HTH
Mike n Mo
10-22-2013 15:17:53
If your A has a Rollamatic, consider switching to a non-Rolamatic (straight) front shaft/pedistal. You'll lose 50# and drop the front about 2" or so.
Mike
Old Popper
10-22-2013 14:28:30
Yes, 15" rims from an older B will bolt right up.
