I have a early (1964) 4020 Synro, Diesel, wide adjustable front end. The output pipe on the main pump was replaced years ago with a hose and is now leaking due to wear and rubbing on the frame. My question is is there an easy way to get to the fitting at the pump or do I need to lower the front end frame to access the pump. I can get to the fitting but there is not much room for a wrench.
Any tricks of the trade or suggestions would be helpful.
If the front end has to come off can it just be lowered or does it need to be removed completely?
Also does any one have a source for and/or the specs.( ie. wall thickness, id , etc.) for the 3/4 inch and 3/8 inch steel tubing used on these tractors. I have a flair tool and can get a bending tool just need a source for the material as I would like to put it back as close to original as possible.
