Gasoline filter
PopinJohn
Anyone have the part number for the pleated paper type gas filter that will fit in the tall sediment bowl?
I saw one this weekend on a G JD, man said it came from NAPA auto parts, but he didn't have a part number or the box it came in. Thanks.
I think it might be G124, but that's a lube finer filter number. I know that they were used in early 60's cadillac cars among some others.
Better yet, check out the filter that Deere used on the 6620 combine. It's made of a fine nylon or similar mesh material.
Tyler in MO
by the way...If you were at Canandaigua, I'm sorry I missed you.
It's a WIX 33034, I got mine from Stiener, I tore mine up trying to get it into the glass, I have a aftermarket sediment bowl from NAPA. It was too tight for the aftermarket bowl.It may fit in a original bowl. It may be bigger. Hope that helps.
Thanks, Tyler
Actually, this year I went to Waterloo. Wife and I had other business in Missouri the same weekend as NY, and I hated to miss Canandiagua, so Waterloo was how it went. Waterloo was missing a lot of vendors.
Napa Gold - 3039.
John Deere - AH96221.
I have used both.
With the napa filter, you cannot see when its plugged or has water in it. Freezing temps will break it down if water is present.
The John Deere filter works the way a bowl filter should, and so far has lasted much longer.
For get NAPA , there is one avail much better and lasts indeftently. AH96221 $14.46, check it out at your dealer next time you drop by.
