update on my 3020 hyd problem
dieseldoc
well I messed with it a few more minutes and and found the problem. looks like I am going into the rockshaft. pressures are good as long as the rockshaft is down . lift it up and hydraulics don't work hardly at all. thanks for the help.
Rowcrop 3 pt valves don't have a history of leaking unlike their utility cousins. If it were my tractor I try adjusting the L/D settings as outlined in a JD service manual before I pulled the valve housing off. It could be a matter of just the operating valves are set too tight which can be adjusted from the outside. Does changing L/D lever under the seat affect the internal leak?
