5325 Steering Wheel
turklilley
06-13-2013 16:57:01
The Steering Wheel on these tractors are adjustable. You can move it forward to ease mounting and dismounting, and adjust position. Mine has quit locking in place. The online parts shows only the entire steering column as a replacement. Has anyone taken one of these apart to repair the position lock? What is in that little cylinder that locks it?
Tx Jim
06-14-2013 03:48:46
 Re: 5325 Steering Wheel in reply to bollweevil, 06-13-2013 16:57:01
It appears to me that parts key #6 is what locks steering column in place. On other JD tractor model it's described as a kit which leads me to believe #6 is the problem
Bob
06-14-2013 07:45:18
 Re: 5325 Steering Wheel in reply to Tx Jim, 06-14-2013 03:48:46
#6 operates a valve BUILT INTO the gas strut that releases the strut internally to allow adjustment. You could toss the pedal away and it will remain locked.
I repaired a (similar) 6400 that was oily around the strut and wouldn"t lock, it subbed to an updated strut, as does this one.
Bob
06-13-2013 22:36:06
 Re: 5325 Steering Wheel in reply to Old Bob, 06-13-2013 16:57:01
Gas-filled cylinder Part #AL209275.
Bob
06-13-2013 22:32:52
 Re: 5325 Steering Wheel in reply to turklilley, 06-13-2013 16:57:01
What is your serial #? I looked at the PC for the older serial number and the gas-filled strut is available separately for about $150.00, at least for those. (Key # 11.) Is that what you mean by "have to buy the whole column?
Third Party Image
turklilley
06-14-2013 20:39:26
 Re: 5325 Steering Wheel in reply to Bob, 06-13-2013 22:32:52
Mine is slightly different. They want to sell everything from #23 up, as a unit. Thanks for the Part number, that may help.
Tx Jim
06-15-2013 03:46:12
 Re: 5325 Steering Wheel in reply to turklilley, 06-14-2013 20:39:26
Boy I'm glad I own a 4255 with a mechanical latch on tilt steering that with over 10,600 hrs is still working the same as it did the day it rolled off the assembly line.
AL209275 Gas Operated Cylinder ADD 149.71 USD
