2150 vs. 2020
1 Dollar
05-31-2013 07:30:42
How does a 2150 compare to a 2020? I see it"s rated at less power and only a 3 cylinder. Does it feel much smaller? I"m looking to replace the 2020 with a similar sized tractor, just a bit newer. The 2020 will run a 9ft 1219 MoCo, I feel the 2150 would struggle? Would the 2nd remote off a 2020 bolt on to the 2150?
Thanks
jd2cylman
05-31-2013 17:12:04
 Re: 2150 vs. 2020 in reply to 1 Dollar, 05-31-2013 07:30:42
Years ago, we did the same thing. Traded the gas 2020 w/ 48 loader on a 2150. Don't remember which loader we put on the 2150, but it wasn't the 175 the dealer wanted us to buy. We put a much heavier loader on it. It was twice the tractor that the 2020 was. I think both tractors had swept back front axles. The 2020 had horizontal exhaust under the LH platform. Great in the winter. Not so much in the summer. The 2150 had under hood muffler. Very nice.
Adrian
Tx Jim
05-31-2013 09:11:28
The 2150 will be shorter wheelbase unless the 2020 has sweptback frt axle & 2150 has straight frt axle. I think the 2150 should pull a 1219 just fine as I have pulled a 1209 with a 2040 with no problems. Yes the SCV's will interchange with no problems.
This post was edited by Tx Jim at 13:02:06 05/31/13.
D-
05-31-2013 12:22:15
 Re: 2150 vs. 2020 in reply to Tx Jim, 05-31-2013 09:11:28
Advantage of a three cylinder: No balancer shafts!
