Jd 2010 remote hydraulics (1964)
Mike ibach
05-24-2013 18:43:52
Thanks for the help thus far! I'm still having trouble with my front loader. All hydraulics worked before I started to change fluids/filters and paint. 3 pt and power steering work very well. I did top off fluid with another gallon. Still no remotes. Could my remote hydraulic control be bad? When I action the loader up or down, you can hear the pump and the motor will strain. I'm trying to understand the remote control. If its not allowing fluid to pass that would answer my question. The hoses spin freely, however I can't get them to release from the remote control. I've tapped on the sides. Any help would be much appreciated, can I bypass? Thanks, mike (auburn,ny)
Tx Jim
05-25-2013 05:09:22
 Re: Jd 2010 remote hydraulics (1964) in reply to Mike ibach, 05-24-2013 18:43:52
Does your tractor have factory breakaway couplers? If so the lever(parts key #33)must be pointing straight back for removal of male coupler plugs. Parts key # 33 controls oil flow . Down allows oil to flow,straight back shuts off oil flow.third party image
This post was edited by Tx Jim at 05:10:34 05/25/13.
