fuel line ferroles
36 A
04-30-2013 15:43:14
What is holding the ferroles fuel lines ? are they soldered on ? I had one red and it didn't move .
Mike M
05-01-2013 08:07:08
 Re: fuel line ferroles in reply to 36 A, 04-30-2013 15:43:14
Early ones can be just soldered on. Most of the lines I worked with were later and must be fusion welded or something as I could never get them apart either. I ended up cutting the old line off flush then carefully chuck the ferrel in the lathe and bore the old piece out so I can then resolder a new line back into them.
husker44a
04-30-2013 17:10:45
They are soldered on. I had the same thing happen to me. Just replaced them.
