Recently acquired a 1952 MT. I"m not much of an "electrician", so I"m on a learning curve. The previous owner installed a new 12v battery, but I suspect I have a 6 volt system. The tractor has what I believe to be a generator (picture attached). This unit is a Delco-Remy. The tag has been painted over, but I"m pretty sure it"s as follows - "11C(?)1857 2F 3". (The "C" is questionable.)
I may be wrong, but I was under the impression that 6 volt systems use a generator and 12 volt systems use an alternator. Is this correct? What is the best way to identify the Delco-Remy part? Also, what is the proper way to check the output for charging?
I"m interested in taking this tractor back to a 6 volt system.
